skam84 6
you have a way to force Motion Sensor that performed some action, for example,
if the motion sensor is tampered with and disarmed do something
But here there is a problem .. it stops working when the senor non-stop sees such movement.
if the light switch and motion sensor is tampered with and disarmed turns off the lights for five minutes
then we have a problem if the motion all the time will see movement this has ever happened, this scene will not perform because .. the status of the sensor shows the tampered with eg 4 minutes ago but the whole time sees PIR motion.
How can I force Multisensor to that in the case of detection of continuous movement (eg to move around the sensor for 10 minutes) during this time he did not start the stage to prolong the residence light and shuts off the light to us. The scene will only work if we leave the sensing MotionSensor and again we get back in his reach.
My scene below .. uses autoLight but it does not much because she has prolong the action of xx seconds.
Any idea? Maybe possible in LUA?
