I would like very much to measure the temperature in four adjacent rooms (max distance 8 meters from furthest points).
Ideally I would place a FGBS-321 in a central hall with a 12 V power supply, then I would use 4 3 wires cable (RJ11) and will install 4 DS18B20 (one per room)
Is this possible?
How can I distinguish among the 4 different readings in the 4 rooms?
Does anyone has a similar experience?
Thanks in advance
Roberto
