anu 0
I would like to share my experience that cost me two weeks.
I hit the mesh network reconfiguration for entire network on my HC2 then nodes are starting to die, in a day almost all nodes are dead.
All AC powered nodes are dead only AEONLab Muti-sensor continue to work but show some incorrect data, such as show high temp (70c+) and trigger potential fire.
I try to add/remove nodes but no success, but some devices will able to add/remove by put extremely close to the box (few centimeters).
I reach Fibaro Support by email and they think it's antenna problem, and suggest I tried HCL, I tried on HCL and experience the same issue.
Then I root the device and found that something is flooding /tmp/Zwave.log and then I realized what's the problem.
So I would like to share cause and symptoms on this case:
Thank you.
5 answers to this question
