mefubar99 0
I have a global cache close contact device and I can send a single command to the device using a virtual device without any problems.
eg to turn ON to the first relay I would send the following string command: setstate,1:1,10x0D0x0A
The question I have is how can I send 2 or more consecutive commands in a single virtual device button ? In other words, if I want to send an OFF command straight after the ON what is the format I use ?
I have tried all sorts of combinations to combine (just guessing really) but it doesn't work.
Do I have to use LUA to do it ? If so, can someone please help with the code ?
9 answers to this question
