Hello everyone,
I just install another linear dimming switch
I only had 3 wire in the box .Neutral power and load.  I connected both wire , white and blue to the load. When poweroff, the light still lit a little. When power on at 100% the light go on and off and on and off forever,  Do we absolutly need 4 wire to make these switch work properly?
Thank you
David
(ps light is LED)
