Quick question!
Can anyone else confirm that power metering as part of a mesh network sucks? yet with direct communication with controller it is very reliable?
I can simply move my antenna from one side of a room to the other to enable or disable power metering on 2 devices yet switching etc works perfectly!
Is power metering class an issue on Fibaro controller as part of a mesh network? or am I just unlucky and stuck in a signal issue bubble in my property?
This is with a standard stubby antenna / a 9db antenna or even a beat of a 20db antenna used for long distance
It seems regardless of antenna the power metering is always first to fail! I seriously cannot justify another gateway for (1) device!!!
But can i justify a bug report if other suffer the same fate?
