I am new to Fibaro but managed to set up part of my system.
Now I want to configure the FGS-222 to turn On and Off a lamp. I have 2 switches in parallel that goes to terminal IN1 these are momentary keys(Push buttons). The lamp is connected to relay output 1.
How do I setup the HCL parameters to get it to work? I tried different settings but not really got it right. in one setting I got it to toggle by pressing the button extremely short time.
If the lamp is OFF I want it to go on if I push any button. If it is ON I want it to switch of by pushing any button.
I do not need any Automatic Turn off delay.
Thanks for any help.
Helge
Helge
This is 2 x 1.5kw relay - correct ?
I don't think it can setup to work effectively with a momentary switch. Typically I have used just standard toggle (on/off switches) and they work just fine.
is there a reason you are using a momentary switch and not a toggle (on/off) type ?
BTW - I have used momentary (and 2 way retractive switches) with the fibaro dimmer module (FGD211 and 212) and parameter 14 is used to specify which one.
-Frank
    I have 2 buttons.
    One on top of the stairs and one in the basement. I would like to turn on and off at both places.
    //Helge
    yep,that looks correct and should work if you use ordinary on/off switches
    in your diagram output 1 can be switched by either of the two switches or by the controller
