Impossible to backup configuration
Recently I've upgrade HC2 from beta 4.062 to 4.070.
Now I can't execute my configuration backup.
Execute backup procedure but stop after some seconds.
Someone can help me?
20 answers to this question
Take out USB stick... Put into pc add an empty folder called backups then try again
    I've just tried with different HC2 and I've the same problem.
    Now I will try to empty the backups folders
    Same problem.
    Now the backups folder is empty.
    Impossible to execute backup.
    Same problem.
    did the folder exist in the first place?
    The backups folder was already present.
    that was not your issue then
    /emoticons/default_smile.png" alt=":)" srcset="https://forum.fibaro.com/uploads/emoticons/[email protected] 2x" width="20" height="20" /> unless the folder is corrupt? or another issue? me personally i would bite the bullet and delete the folder then recreate it (but i live life on the edge)
    I try it but very strange on 2 different HC2
    I have had exactly the same problem twice... first time fibaro remote fixed it... second time i researched the issue and came to the conclusion when i looked at the usb stick that the folder was missing altogether!
    It is now backing up fine again!
    Guest chaicka
    Please correct me if I am wrong.
    The usb stick of HC2-#A cannot be use on another HC2-#B since the usb-stick has some sort of token-key tagged to the HC2 unit. Right?
    Not entirely sure how true this is? And i for one would not like to put my neck on the line
    /emoticons/default_icon_wink.gif" alt=";-)" /> maybe someone else would like to? but copying backups folder including scenes etc from the pen for use at a later date or another unit/usb i do think is very possible!
    I've delete and create the folder and now is OK.
    I can backup the configuration.
    excellent news
    Good news for the solution but for me a bug.
    Two different HC2 and same problem after upgrade.
     I have the same problem. Allready emty the backup directory and did a restart of the system. Last backup was almost a year ago en were all incompatable. Recovery memory is read only checksum status is Corrupted (Calculated checksum does not match (broken image). please help
    YUK! Hope your HomeCenter does not get travel sick! Think it maybe making a visit to Poland!
    Is there no other way to solve the read only problems from the recovery disk. After a possible visit to Poland is the system still working because I dont have a Backup of the system.
    only people who can answer that '[email protected]'
    Interestingly, my HC2 shows that the checksum is ok. Deleting a backup worked, too - but creating one is not possible. It counts down, reloads the page, then even the z-wave engine is restarting (excellent trick to re-start the network without reboot though) - and nothing, no backup is shown.
    Support said, I will have to ship to Poland..
    Sad story with this backup...
    /emoticons/default_icon_neutral.gif" alt=":-|" />
    I have exactly the same problem. It counts to 26 and than reloads the page. No backup..
    However I know why MY HC2 does this
    I'm sure that my reason is not the same as yours!
    Users who can not backup, can you please try if Configuration > Location > Safe Settings is working for you?
