Hello to all,
I purchased a hcl with 3 motion sensors fibaro, unfortunately not reading enough I installed the beta version 4.063 not knowing that I can no longer do the downgrade and so I could not test it with a stable version.
My problem is that sensors do not go well, that is closer to the hcl works well but the less distant malfunction to disconnect, all on one floor at a distance of about 12 meters.
You can not increase the power on hcl (the taso + what is?)? is a problem of beta?
So out of hand I do not think I made a good buy .....
Thank you
Hi. Having the same problem.
Buy a Fibaro Wall Plug and place it in the middle distance between the HCL and relays. Will work as a repeater for Z Wave signal.
But still add both devices close to box then move
