Scene triggered by global doesn’t start if I change it from API
Dear All,
I have a scene triggered by global that sends push notifications.
when I change the global variable form an other scene it works properly.
If I make it from api (php script and HC2/docs) the value changes in the panel but doesn’t trigger the scene.
It’s very strange.
Do you have the same problem? Any suggestion?
Thanks in advance
5 answers to this question
As already written here:
This worked for me!
So just add "invokeScenes":true (case sensitive!).
I hope it will work at your place too.
    Dear Wallstreez,
    I use a php script whit CURL and it works fine.
    Here the code:
