Efficient Code
Just out of interest something as simple as this works in my virtual device! But it seems so much code for such a little result? Could it be reduced and more efficient? any helpers? this is more for my learning curve than to prove anything more!
You can create an array with triplets (valueID,callID,labelID) and iterate this array.
So you will need only 8 lines of code.
As a not working example:
This can even be optimized
    i have myself an error and i have done some research regards lua arrays on google but they seem to be less complex eg.
    a = {1,2,3,4,5,6}
    instead of multiple values in each.... anyone spot my error?
    thank you
    Fixed it thank you Alex... i made silly error!
