House Occupancy - check my logic to determine
Looking for some input into the logic for a scene before I begin to code....
Background - I am looking to determine occupancy both upstairs and downstairs in my house. A lack of occupancy in either floor would then trigger lights/music/etc to be switched off. Lack of occupancy on both floors would assume no house occupancy (with some other checks ) and this can be used to auto-set our house alarm. No movement detected for 30 mins assume no occupancy. I am using my standard alarm PIR's as I can see status of those in my HC2
approach...for first floor...
assume no occupancy (uo_occup = "no")
1) PIR trigger in landing starts scene
2) sets up_occup variable to 'yes'
3) start counter
4) recheck every 15 seconds - if PIR =yes then reset counter
                                           - if PIR = no then increment counter
5) if counter reaches 120 ( this is 30 mins at one check per 15 seconds) then set up_occupancy = 'no'
6) Scene stops
Next breach starts the scene again
Some peripheral checks to cover corner cases.....
If Alarm = partsetA then up occupancy = yes and hence house occupancy  = yes
If Alarm = Fullset then house occupancy is no
If back or front door is opened then down_occupancy = yes
Do people think this would work or are they other approaches ?
-F
