I just got an email form BOSE after a request for a example ON/OFF button for SoundTouch S20 using API codes.
I will put the informations from the email here.
import requests
import xml.dom.minidom
# Val options:
# PLAY
# PAUSE
# STOP
# PREV_TRACK
# NEXT_TRACK
# THUMBS_UP
# THUMBS_DOWN
# BOOKMARK
# POWER
# MUTE
# VOLUME_UP
# VOLUME_DOWN
# PRESET_1
# PRESET_2
# PRESET_3
# PRESET_4
# PRESET_5
# PRESET_6
# AUX_INPUT
# SHUFFLE_OFF
# SHUFFLE_ON
# REPEAT_OFF
# REPEAT_ONE
# REPEAT_ALL
# PLAY_PAUSE
# ADD_FAVORITE
# REMOVE_FAVORITE
# INVALID_KEY
# enter the IP address as a string:
ipaddr = "xx.xx.xx.xx"
# enter key value:
val= "PRESET_1"
# for every button press, also show the speaker info
infoRequest = requests.get('http://' + ipaddr + ':8090/info')
infoResponseXML = xml.dom.minidom.parseString(infoRequest.text)
infoResponseXML_pretty = infoResponseXML.toprettyxml()
print infoResponseXML_pretty
# press
pressXML = "<?xml version='1.0' ?><key state=\"press\" sender=\"Gabbo\">" + val + "</key>"
press = requests.post('http://' + ipaddr + ':8090/key', data=pressXML)
pressResponseXML = xml.dom.minidom.parseString(press.text)
pressResponseXML_pretty = pressResponseXML.toprettyxml()
print pressResponseXML_pretty
# release
releaseXML = "<?xml version='1.0' ?><key state=\"release\" sender=\"Gabbo\">" + val + "</key>"
release = requests.post('http://' + ipaddr + ':8090/key', data=releaseXML)
releaseResponseXML = xml.dom.minidom.parseString(release.text)
releaseResponseXML_pretty = releaseResponseXML.toprettyxml()
print releaseResponseXML_pretty
My question is : How can i transform this in LUA language for that virtual device?
                          I'm beginner in LUA language so i need some help
/emoticons/default_sad.png" alt=":(" srcset="https://forum.fibaro.com/uploads/emoticons/[email protected] 2x" width="20" height="20" /> .
I tryed like this but is not working.
Any help ? Thanks.
HC2 = Net.FHttp("192.168.2.128",8090)
pressXML = "<?xml version='1.0' ?><key state="press" sender="Gabbo">POWER</key>"
press = requests.post ('
data=pressXML)
or is like this ?
BOSE = Net.FHttp("192.168.2.128",8090)
pressXML = "<?xml version='1.0' ?><key state="press" sender="Gabbo">PAUSE</key>"
response, status, errorCode = BOSE:POST('
', data=pressXML )
  • 1 month later...
    I'm back with a new information , Fibaro can't access XML library
    Guest Roman
    As idea. I like to parse XML using this regexp:
    • 4 months later...
    Coucou tout le monde , j'ai créé un Vd Bose opérationnel, avec les commandes principales, je vous en fourni une première version (n'oubliai pas de remplir l'adresse Ip et le port Tcp de votre Soundtouch).
    Thank you, loic62185, is working perfectly .
    In this time I've made it in other way. With Orvibo IR reader and Wireshark .
    If someone want to try it, use TCP Port = "8090"
    Regards.
    Merci Loic62185
    N'hesites pas a poster les mises a jour s'il y en a.
    • 2 months later...
    • 4 weeks later...
    /uploads/emoticons/default_biggrin.png" srcset="https://forum.fibaro.com/uploads/emoticons/[email protected] 2x" width="20" />
    Regards.
    What's up buddy, would you mind to explain me how did you do to adquire the HEX commands via wireshark? I have my Orvibo Allone but I'm not pretty sure how can i get the hex commands, thanks!!
    With Wireshark on tablet , you need root and you can install it on tablet.
    Start the program on tablet , use the Orvibo app , in app you want to push all the buttons that you need for wireshark -> stop wireshark ...send the file in you pc ...open with wireshark on your pc .... and there you will find your codes.
    Use this filter  < (ip.src eq 192.168.2.156 and ip.dst eq 192.168.2.178) and (udp.port eq 10000 and udp.port eq 10000) >
    src= your tablet ip.
    dst= your orbivo ip.
    This is an example of Turn On command :
    "686400aa6963accf234b41c6202020202020bd3bcd0c189d9000000000009000bcaed923010058023b048101000311000000760040206710c5015906c5016602c5016802c5016602c4015906c3016702c4016602c3016702c5016602c5016702c4016702c6016602c4016702c6016602c5015a06c4016702c5016602c5016602c6015a06c5015a06c5016602c4015906c3016702c5015a06c6015a06c5016702c5015a06c6016602c401"
    Cheers.
    • 1 year later...
    For Soundbar 700 also should work?
    • 7 months later...
