MaTi 29
Hi all,
I have been trying to achieve something which maybe is possible, or maybe isn't. If it is, I would like your advise..
/emoticons/default_icon_wink.gif" alt=";-)" />I have an ipad hanging on the wall in my living room. Whenever I go to sleep/outside I use this to turn on the alarm.
This works like a charm.
In order to come to a workable situation, I have excluded my FIbaro motion sensor located in the hall upstairs from the alarm.
This because when I am home and I need, for instance, go to the bathroom, I will pass this sensor and it will be breached. Not really a situation where the alarm should go off
/emoticons/default_icon_wink.gif" alt=";-)" />However, ideally I would like this sensor to be included as well (and some others, but just this one now to use as an example) in case I have left the house completely.
Ideally, I would like to have 2 alarm 'scenes' (or whatever you call it) on the main page of my ipad app. One to select when I go to sleep (ignoring states of the sensor upstairs) and one when I leave the house (all armed with a delay of 60ish seconds). Is there a good way to achieve this? I have thought about working with scenes for this, but the switch I am currently using on my ipad isn't a scene.. It's from the alarm module in the HC2. (or does making scenes where you set specific devices to ARMED with a specified delay result into the very same result as enabling the alarm module as I am doing now, when you turn on the scene?)
Any help or advise is highly appreciated! Thanks
/emoticons/default_smile.png" alt=":)" srcset="https://forum.fibaro.com/uploads/emoticons/[email protected] 2x" width="20" height="20" />9 answers to this question
