The possibility to choose a variable and set ander Shortcuts> heatig> under configuration
Hi
I have a suggestion.
The possibility to choose a variable and set ander Shortcuts> heatig> under configuration.
1 = main moduleSelect the main module, eg temperature sensor on the first floor or in heating zone no.1 is OK
2 = switch 1Switches, responsible for the activation and deactivation of the heating in a zone..........OK
3 = switch NaNSwitches, responsible for the activation and deactivation of the heating in a zone.
select switch: VARABLE      and Set False or true.
Or a virtual switch and sensor.
Or please the users enabled plugins.
I ask them to set up a variable to assisst the opportunity to be used for extensive Scripts.
Thank you very much
    Hello.
    There are no novelties to my contribution.
    Ask for an answer.
