Amazon Echo voice control for Fibaro (using virtual WeMo bridge)
Guest minimax
Hi folks,
I bought Echo on my vacation in US this week and decided to do an integration for Fibaro.
After doing some research I made a decision to use WeMo bridge (thanks Chris -
and bend it for Fibaro.
Here is my first 'alpha' so far so good version, which automatically enumerates light devices and announces them using WeMo bridge.
Install guide:
WeMo bridge is a python script that runs on your pc or server or another python-equipped thing.
Windows users:
====== Python installation (optional) ======
1) download python 2.x (2.7.11), not 3.X !!!
2) Install python with launcher and add to PATH option
3) run command prompt with admin privileges and execute:
=========== fauxmo bridge:============
4) download fauxmo_fibaro attached at this post and extract it.
5) edit fauxmo.py with notepad and add correct values to these lines:
I recommend creating a special fibaro user just for alexa. Do not forget to assign device privileges for this user!
6) Save file, doubleclick it, or from command shell run: fauxmo.py
    You can add -d to the command line to show debug output
7) Bridge should run.
8) From alexa app, go to Settings > [Account]/Connected Home > Discover devices
Alexa should find all light devices now
9) Enjoy!
4 answers to this question
Hey Minimax
You still working on this?
why is this not working...
Traceback (most recent call last):
File "fauxmo.py", line 412, in <module>
devices = f.enumerate()
File "fauxmo.py", line 385, in enumerate
json_data = json.loads(r.text)
File "/usr/lib/python2.7/json/__init__.py", line 338, in loads
return _default_decoder.decode(s)
File "/usr/lib/python2.7/json/decoder.py", line 366, in decode
obj, end = self.raw_decode(s, idx=_w(s, 0).end())
File "/usr/lib/python2.7/json/decoder.py", line 384, in raw_decode
raise ValueError("No JSON object could be decoded")
ValueError: No JSON object could be decoded
Not that I can test this (as I don't have an Echo yet) but I think the Echo supports Weemo already and if you follow the steps in my post below you may be able to integrate your Echo, Weemo and HC2:
