Help with LUA Code - Storageroom light
My LUA coding knowledge are limited, learning all the time but it takes time
Have a storageroom which has doorsensor, movementsensor and light switch.
Unit numbers are:
298 = Doorsensor
282 = Lightswitch
302 = Movement Sensor
Everything is Fibaro products
Want to have this functions:
1. When door opens lights should be turned on
2. When no movement in room for 5minutes (300sec) lights should be turned off even if the door is open..
3. If light is off and door is open and new movement is registerd in the room then light should be turned on again.
4. When door is closed light should be turned off.
Have this in "Block Scenes" today, but it takes 4 different scens to get it running and I get a lot of "Too many instances" messages, so I want to change this to LUA code to better control what is happening.
Could some friendly person help me with an example?
10 answers to this question
Can be done even with simple block szenes.
With Fibaro Relay look for parameter "Auto off for relay X"
with the 2x1 switch it is 4 or 5.
Set this to 300.
Then you can trigger on door open or Movement = turnOn
Door close = turnOff
no timers or anything else and you shouldn't get too many instances
Borgen
Did you manage to create LUA scene ?
Why do you need a door sensor and motion sensor. surely just a motion sensor will do what you want?
Borgen,
I think qordz is right...
Your fourth condition says to turn off the light if the door is closed, but if I close the door and stay in the storageroom, the light should be ON, right? So the light should be controlled by movement and not by door's state.
Please give a second thought what exactly you try to accomplish, otherwise you'll need to fix and debug the scene for a long time.
Spot on.
    Borgen,
    Thanks for your thoughts around this, there are probably different situations where my setup is not a suitable solution. But in my case and in the room that I am trying to configure I want the following functions:
    - When the door is opened the light should turn on at once, not after that I have opened the door and walked into the storage room.
    - Light should be turned of after 5 minutes if no movement in the room
    - If new movement in the room after 5 minutes the light should turn on again.
    - when door is closed the light should be turned off.
    In the particular storageroom it is never the case that we close the room and still are in the storageroom,
    So in other cases I could agree that a door sensor is "over-kill" but in my case I want it.
    I have given up the thoughts to do this in a "regular" LUA code. The reason for this is that I found (with help from Jompa68) the very interesting GEA project. So I have implemented GEA in my HC2 and have now moved all of the light control in my house from "Block scenes" into GEA and have reduced the amount of scenes from 45 to 17 in my system.
    GEA is a really interesting project and I am surprised that it is no threads in this forum around the GEA project, on the French forum there is a 296+ page long thread on the topic. It is an extremely strong "tool" that can do amazing things...My problem is that everything on the French forum is in French language, google translate can assist but it sometimes get strange
    Guest SPyRoX
    Hey Borgen
    I can't find anything about that GEA project. Do you have a link to it?
    And i know the feeling about the French language. i can't understand it either.
    SPyRoX,
    The GEA Project can be found here
    Honestly I don't see any advantage to use GEA, every thing could be done in LUA  and to my opinion in much better and efficient way.
    But may be I'm missing something... could you share more info how it reduces scenes (in your case from 47 to 17!). As I understand it just combines few scenes together, but it could be done in LUA as well.
    Note:
    LUA is widely in use for several controllers (not Fibaro only) and other systems, so I believe is better to know LUA instead of learning other code which looks like built for Fibaro system only.
