Simple Slider to change Dimmer
hi Guys,
Looking for simple function/code to change the value of a dimmer based on slider. cant seem to find any reference to this on forum or net.
Thanks in advance
6 answers to this question
    SOLVED
    Not sure if this is the best way to do it, but thought id share for future reference for newbies like me :
    on the Virtual Device Slider, Type Lua
    What im doing is getting the value of that slider and setting the dimmer to that value.
    How does the slider on VD gets its initial value?
    I tried
    in the main loop.
    But that runs every second and "overrules"  a slow move with the slider.
    if you want the slider to set the dim value of the light then paste this code in the slider object:
    Change LIGHT_ID to the ID of the light being controlled.
    To set the slider value to the current light value paste this in the main loop:
    Update Slider123 = with the ID of the slider
    Change VD_ID to the ID of the virtual device
    SOLVED #2
    Thank you Aleks,
    Clean code and it runs perfectly.
    Hi, is there any way I can control a slider on HCL?
    Firtsly very new to coding , I am trying to control a shelly dimmer with a slider.  Here is the code that I have but it isnt working.  Can anyone help?
    local device    = fibaro:getSelfId()
    local ipaddress = fibaro:getValue(device, "IPAddress")
    local port         = fibaro:getValue(device, "TCPPort")
    SliderVal = fibaro:getValue(145, "ui.Button3.value");
    fibaro:call(145, "setSlider", "3", "SliderVal");
    fibaro:debug(SliderVal);
    Kenny
