Fibaro Dimmer 2 and 16 LED bulbs possible?
Hi to everybody.
I have a question. Can I connect 16 LED from Philips MasterLED 5,4W to the dimmer 2? Or is the load of nearly 100W too much?
For a lot of dimmers you always read that for led you have to cut the max dimmer power by 4 to get the max value for LED to connect. The manual says 200 W for LED bulbs.
Thanks a lot.
Regards lulu
Hi lulu,
should be no problem at all. I have 12x6W with Dimmer2 and no Bypass - working well.
regards,
gruberb
Hi to everybody.
Thanks a lot.
Regards lulu
Posted 09 March 2016 - 12:03 PM
Hi lulu,
Are you guys able to dim low with these  bulbs ?
the reason for my question is that i have 16 ikea led bulbs on a dimmer 2 and they do not go as low as i wanted..
about 200-250W is the max for Dimmer 2 (ive found), so as long as you dont exceed that, your be fine
(so around 70 would be possible - in theory anyway!!)
