northyorks 35
I have made a slider in a virtual device for my lightwave lights. They have a normal range of 0-32, so in my virtual device slider i have used:
local LWRF_DimLevel = math.floor((_sliderValue_ / 100) * 32)
However when I put the slider between the values of 0-4 (so very dim) the actual light level goes to 100% brightness.
I assume my math.floor must need changing?
Or is there any code I can use to not allow the slider to go below say 5?
Or if slider <5 then 'press button' off for example?
