I have a FGS222 installend behind a double switch. Manual operations work fine. I managed to include the relay through OpenHab. After some problems I tried to do an inclusion through a Aeotec Gen5 Stick.
I am unsure how to effectively reset the relay. As I said the relay is installed already behind a switch.
I tried the inclusion by changing the switch three times while the controller is in inclusion mode. Right?
How to exclude?
I tried to reset the node by switching off power in the whole floor and after power is back, I changed S1 and then S2 into a new position. Is that right?
How would I exclude without removing power all together?
i guess there is a small button on the device,
first choose exclude en push the button 3 times
then include and press the button 3 times
    The device is already installed behind the wall. It was quite some effort to get it there. So is that the only way... to get it out of the wall?
    Exclusion is like inclusion, I'm reasonably sure I've done this before (but not every week). The only devices I have to remove to remove from the wall, are UBS, because they don't except commands on their inputs. Set the controller, any controller to exclude devices. Triple click if S1 is a momentary switch (p14=0). For toggle switch: perform 3 position changes of S1. If I remember correctly, a 4th click/position change cancels the procedure.
    Sometimes you get fastest help by reading the manual.
    Excluding Fibaro Roller Shutter from the Z-Wave network:
    1) Make sure the module is connected to the power supply.
    2) Set the main controller into the learn mode (see main controllers operating manual).
    3) Triple click the B-button or a push button connected to the S1 terminal.
    I dont guarantee but you can try resetting roller shutter like this also:
    1) Turn off power from roller
    2) Press and hold down S1 key
    3) Return power to roller shutter
    It worked for relays  like this, but im not sure about roller shutter. In manual they say to use B-button for reset procedure.
    Thanks for your comments. The device is not a roller shutter but a 2 way relais, and the reason why I am asking is that I have problems. It seems that I messed everything up.  You can be assured that I read the manual and tried a hell lot of things....reset the controller stick, exclude, include ..... trying to reset the FGS222 .
    The hint regarding the fourth position change is quite good.
    • 4 months later...
    I need some help. I can not exclude my Roller Shutter about a toogle switch. I've tried three position changes(S1)but it isn't working. Can anyone help?
