Problem with HC2
I have suddenly a problem with the HC2. I was trying a couple simple things with a virtual device and suddenly i was not able to save any new changes to a VD or anything else. Not sure what happened. So i did try a reboot from the HC2 web interface, but it is not rebooting. In the interface everything is clickable, i can navigate through the pages.
So i turned it off with the button on the back and turned it on again. But still i have the same problem.
The 3 blue leds on the right are turned on, but the z-wave led was blinking on boot, but keeps turned of currently.
In the top log in the HC2 webinterface i can see:
[22:07:20] Opening port
[22:07:20] Initializing Z-Wave
[22:07:20] Pthread Initialize
I am not able to switch any devices anymore. So something is wrong.
What to do? Any idea?
5 answers to this question
    Anyone a suggestion? Do in need a reset and than try to restore a backup?
    You can trie to clear cachememory,
    Hello Sonnyboy,
    What for cache? The browsercache? I did try this. I also used Chrome and Firefox, both with the same problems.
    Or are you talking about another cache?
    Roland
    i did got it working again (after a recovery). It seem to reoccur after assigning rights to a new user. Not sure what this is. I also report this to Fibaro support.
