Hikvision Virtual Device
Has anyone configured a Hikvision camera as a virtual device?
I'm trying to integrate my new Hikvision 2142FWD cameras so I can arm, disarm, etc. I think I'm on the right track by creating a virtual device but is there a list of the HTTP commands somewhere?
How has everyone else done this? I want to have the cameras send me some images and/or video of the previous 30 secs from an alarm trigger. Is this something the fibaro can do or more of a NVR function? I'm currently using Synology Surveillance Station.
On 24/3/2017 at 6:52 PM, rusconidesigner said:
I've tried the
 VD and it works like a charm! But, I have a e questions... Is it possible to send only a part of the XML block and not the full command?
For example this is the full XML block:
I would like to send only a part:
Because, there are some very very long  XML block response.
Thanks in advance
Hi
Did you have found solution regarding this topic?
Thanks in advance
Gianluca
On 6/4/2018 at 3:57 PM, Gianluca S. said:
Hi
Thanks in advance
Gianluca
Good Morning Guys,
I have tried to test a reduced version of XML with only the tags that i want to change, but seems that not work.
Im using the Motion in Expert mode, but the xml "MotionDetectionExt" is too long...
Any suggestion?
I have been successful in applying beebie's VD to my DS-2CD2135FWD-I camera. Unfortunately I'm not at all an expert in adapting further this VD to my needs to e.g. not only let it work for the Normal Event MotionDetection mode in which a selected area for detection is set but also for the Smarte Event  Intrusion Detection and Line Crossing Detection modes since that probably would help me a lot to reduce the number of false notifications received via e-mail. So any advices or sharing of any VD solutions tackling this problem would be very much appreciated.
On 8/18/2017 at 9:45 PM, Bou3 said:
maygel,
In your browser you could try:
. This will also show Line Crossing activity. However I couldn’t get this to work in Fibaro since this is a multipart XML stream.
So I used the log file instead and it works like a charm!
The output of my camera (also I model) will activate a Fibaro sensor. The HC2 will then request a log file from the camera and look at the last few seconds. If there is a Line Crossing present you can turn on a light, or if the camera lens is covered you can activate a siren and send push notifications to all users… etc. etc.
I found the syntax in “IP Surveillance API (RaCM Part) User  Guide” (google is your friend) and used Wireshark to fine tune my code. Look for: POST /ISAPI/ContentMgmt/logSearch. Tricky part is to determine the right start and end time in your request.
Good luck!
Hi Could you share your work with HikVision and  Line Crossing activity?
