HC2 cannot configure Qubino Relay switch?
Hi
I'm trying to include a qubino relay switch, however for some reason my HC2 cannot configure this module. The problem is that the module works (I can switch on/off the light), however I cannot use it in a scene because the HC2 did not configure it yet.
I excluded / included this module now 5/6 times, but no change. Also upgraded to the latest firmware version
Someone?
8 answers to this question
​try exclude include again... (reconfigure wont do) and again.. and there still no template..
    Did you had the same problem with this module. I have more qubino modules but this is the first time I have this type of problem.
    If this is one of the newer plus models, then it's a known issue, reported on bugzilla, but no update yet
    Guest chaicka
    All Qubino modules do not have device template implemented yet. But if you manually add the parameters in, it will still function fine.
    Yes one of my 2 '1D relay' did behave similar. The S1 input works but fibaro will have to do some work on the S2 input to make it work properly. As of now it doesn't really work.
    The "all" is not quite true, I have some of the original flush dimmers (ZMNHDA2 I believe) and they have a template and work fine, The newer plus models (ZMNHDD1) don't have a template and also don't complete configuration
    Cheers
    Guest chaicka
    Cheers
    Thanks for correction.
    Cheers
    I have the ZMNHAD1, I believe this is the a newer version, as my first qubino switch works fine. I will try to add some parameters manually.
    Thx all, keep you posted
