Momos 103
I know that danfoss RS is now a supported device.
So I went out and bought one to test it. Installed it in a room with a danfoss living connect on the radiator.
Inclusion was ok, device seems to be functioning ok even thou it has the same icon as the living connect.
A heating panel is configured for that room.
I was expecting the RS to work as a master device in a room, where you can set the temp manually and it will be transmitted to all the living connect valves in that room.
But it doesn't work that way. If I change the temp on the RS, nothing happens on the radiator valve.
Can someone tell me what am I missing ?
Thank you
15 answers to this question
