I use a lot of dimmer2 products in my house and they are all function pretty well.
However, I have two dimmers that are connected to 2 different lights outside (LED) and both these outside lights keep producing a very small amount of light when I turn off the dimmer completely. The home center reports "light off" and 0.00W. It looks like they are dimmed to 1% (flicker a little) but for sure they are not completely off.
Is this some kind of setting I have to change or does it have to do anything with the drivers in the outside LED-lights?
Regards, Gijsbert
Guest chaicka
Is Bypass 2 being use with the Dimmer 2?
Regards, Gijsbert
Hello, did you find the reason why when off it's not completely off ?
