I have installed the Popp Flow Stop unit to control the water flow to my dishwashing machine. Together with the Fibaro flood sensor i can now control it automatically.
Some pictures
Popp Flow Stop
Fibaro Flood Sensor is breached
Push to phones
Some GEA code that control's the unit
after 180min  when Popp is open it closes by GEA script or if water is under the dishwashing machine
Will order a second unit and install it to my washing machine in basement also now
Note!
I have sent the template to fibaro support because HC2 does not recognise it but it works.
Hej
It`s very good idea for styring of valve.
Where can I buy this POPP ?
What is price of POPP ?
Tack så mycket för denna show!
    look
    Great idea!
    • 1 month later...
    Some pictures
    Popp Flow Stop
    /public/style_images/master/attachicon.gif" alt="attachicon.gif" />
    Push to phones
    Will order a second unit and install it to my washing machine in basement also now :-D
    Note!
    Hi jompa68,
    I've bought a flow stop unit as well, but having problems with inclusion. The HC2 does not seem to recognise the unit in learning mode. The manual talks about two screws to "shut off" before inclusion - Can you clarify what this means? Thanks!
    Cheers
    Alfons
    EDIT: Figured it out - forgot to check "secure mode" while including - works now!
    Looks very good and had one for tests. Unfortunately i could not test it properly, because of very short closures.
    jompa68 does it open havily or smoothly?
    awlieser i got it in HCL unsecured (2x click in inclusion mode).
    Hi jakub
    it opens very smoothly, takes around 4-5 seconds to open/close
    • 4 months later...
    i like it, everything i ran it on added device without anny problem (benefit of device so dumb that its brilliant meaning amazing compatibility).
    I do love the idea that everything can work with everything  (as Z-Wave promissed) alas such occurances are rare and are mostly limited to most basic devices (in terms of functionality).
    Annyways @Jompa how dificult it is to attach the device to pipe? there is quite a few parts in packadge and it looks little inconvinient to me. (particullary how one is suposed to put bolt throu device and 2 things to clamp pipe) Was the alligning of Axis of device and lets call it handle of valve easy?
    Edited by Kuba13
    I bought the needed parts in a local plumbing company, and then I did attach the Popp parts with those supplied parts without problems.
    I will move all the parts later on to fix them directly on the cabinet wall, will take upp less space. But that require some new tubes.
    i was more concerned about logistics honestly (my Flow stopp has everything i can feasibly require for instalation, sans crewdrivers and such).
    it seems to me that the wraparound metal for pipe is not particullary easy to install for likes of me (a clumsy  person - Pat a Mat basically but one guy).
    • 1 month later...
    Additionall question: conssidering you have it as emergency incase something goes wrong, did you associate FGFS with Popp flow Stopp or are you using a scene to run the shut off?
    • 4 weeks later...
    À scene
    Hi all,
    how this POPP Flow Stop is best to consolidate with Home Center Lite and Fibaro flood sensor ?
    Have someone done a block scene to turn of the main valve (POPP Flow Stop) when Fibaro flood sensor recognise a flood? Or is the best scenario to assosiate these two device?
    Help appreciated :)
    3 hours ago, janton said:
    Hi all,
    Help appreciated :)
    I have a problem running Popp Flow Stopp in association to older (non ZW5) flood sensore - it is not closing upon detecting the flood but it dose close when flood ceases.... its akward.
    oh the other hand it dose open when there is flood and close when there is none.... i think they swaped the way it should operate. And its not like i could just pull the pin and twist the arm to where i want it to be the damned device is too smart for that! it just keeps turning and turning until its got grip again and can move the arm wherever the state is suposed to be.
    oh right the point!
    You might want to run it in scene at least until this oddity is mended or fixed.
    Allso thanks for the reply Jompa. I do not supose you'd be wiling to try association technique to see if i am screwing something up or if ti is a genuine strange behaviour. The older flood sensore which allows association of random devices into first group not the new one where first group is Lifeline.
