I have a Fibaro Dimmer 2 and a Qubino dimmer in a room. I'm trying to do some automation by using a Fibaro multi sensor to turn on light based on light levels and movement.
Now it seems the dimmmers are stuck at 80% in the UI even when they were turned off by switch over 5 minutes ago. I'm also not getting any light changes now for a while even I have turned all light off in the room at night the lux should be close to 0. I have configured the multisensor to report changed more than 10lux.
The question is if this can be the same reason they are not updating or separate issues. Can my LUA scripts somehow block the updates?
Regards
Stian
    Looks like a reboot and/or FW update did the trick.
