norphos 0
Hi All,
i've been trying to setup ZXT-120 on fibaro home center 2 but i cant seem to be able to get it to work. Here are the steps i've done.
1. Add ZXT-120 as a device.
2. Go to device configuration
3. set parameter to 27 2d 56 (Toshiba air conditioner)
4. Save configuration
5. Once i go back to device, i noticed that there's a "transfer failed" error message
6. Device becomes a dead node
7. Wake up dead node
8. Repeat 2 - 5 to try different toshiba IR code but the result always leads to 6-7
Is there a way to enable IR learning? Any help will be greatly appreciated.
Thanks.
