Does anyone have any idea how to connect the relay switch or dimmer2 according this schematic.
On last wall switch i do have a N and L wire to supply the power to the switch.
Regards
You can not.  You need to install the relay at the first box, where the load (light bulb) is, or in the ceiling box.  That is if you still want to keep all the switches.
You should take a look at:
