Movement and Door sensor not working as a team,,:(
Hi
Im reading your block, and I like your LUA scripts for Z-wave, Thanks it helps to have something like that to look at,
Im having a problem with My WC that also is a storage for some cleaning things, Using the Fibaro Motion to pickup
moments and turn on lights works well,  It will time out after 2 min, However I also like the lights to be on with no time out when the door is closed.
So I install the Windows/Door sensor from fibaro so it also turn on lights when door is closed and off when then open, however
the Timer on the movements kicks in and turn off the lights after 2 min regardless if door open or closed
Any Tips your able to share ?
Thanks Im not a programmer, but Im able to read logic code if needed
set a variable when the door closes or opens. Then when make the light switch off or time out only when the vaiable changes back, i.e. when the door opens.
    Trying this out, Thanks to Jonas Lundblad m punkt nu Sverige AB
      Facebook:
     Twitter:
    Blog is good and Jonas been helpfull
    %% properties
    372 value
    %% globals
    local sceneId = 16 --ID of this scene, used to detect number of instances run
    local timerEndTime = 180 --Seconds to keep the lamp turned on after PIR detects movement
    local timer = "timer" --Name of global variabel to control the timer
    local timerValue = fibaro:getGlobalValue(timer) --Current value of global variabel for timer
    local doorsensor = 372
    if fibaro:getValue(doorsensor, "value") == 1 then --door closed, turn on
       fibaro:call(lights, "turnOn")
       fibaro:abort() -- exit scene
    else if fibaro:getSourceTrigger() == doorsensor and fibaro:getValue(doorsensor, "value") == 0 then -- door opened, turn off if scene called by door sensor
       fibaro:call(lights, "turnOff")
       fibaro:setGlobal(timer, 0) -- stop timer
       fibaro:abort() --exit scene
    if fibaro:countScenes(sceneId) > 1 then  --if scene is already running , reset the timer to 3 minutes
        fibaro:setGlobal(timer, timerEndTime) --set global variabel for timer to 2 minutes
        fibaro:abort()  -- abort scene
    fibaro:call(lights, "turnOn") --Turn lights on
        fibaro:setGlobal(timer, timerEndTime) --Set global variabel for timer
        while (fibaro:getGlobalValue(timer) ~= "0") do --loop until timer is 0
          timerValue = tonumber(fibaro:getGlobalValue(timer)) --Get current value of global variabel timer
          fibaro:setGlobal(timer, timerValue-1) --Decrease global variabel for timer with 1 second
          fibaro:debug("Loop - timer = " .. fibaro:getGlobalValue(timer)) --debug
          fibaro:sleep(1000) --Wait 1 second
        fibaro:call(lights, "turnOff") --Turn lights off
