Can someone tell me how I can see the status of my variable. I have some scenes that changes my variables. E.g from home to away. But I can not see what variable is active.
i actually use a VD which i have been for a while. attached is my VD just amend the global variable names in the main loop and either delete the labels that are not required or add more and add the extra code...
Thank you.
There is no need to use VD to check status of some global variables. It is also possible to do with scene and popup message:
Every time when you want to check just run the scene, or you can call this scene from another scene when some change is done so later you can check when it happened and what value was set.
Is it a easy way to send the bodyinfo as a push message in the same scene?
To send push notification just add following code at line 32:
fibaro:call(mobileID, "sendPush", bodyInfo)
Replace mobileID with your ID for mobile device. There is restriction on length of the push notification so it is possible that above message will be truncated.
You can also send it as e-mail by adding following code at the same place:
fibaro:call(userID, "sendEmail", titleInfo, bodyInfo)
Replace userID with your user ID. Same goes for e-mail body that is restricted in length and message can be truncated if too long.
