Hey people, what up?
I need your help. I am trying to program via LUA in my HC2 an scene where the gateway can wake up the dead nodes at certain date, down below you will find the code:
%% properties
%% globals
local NB_DEVICES = 20
function wakeupDeadNodes()
    fibaro:debug('Wakeup dead nodes.')
    -- Check all devices
    for i = 1, NB_DEVICES do
        local status = fibaro:getValue(i, 'dead');
        if status >= "1" then
            fibaro:debug(i..': DEAD');
            fibaro:wakeUpDeadDevice(i)
            fibaro:sleep(5000) --check again in 5 sec
                fibaro:debug(i..': Really dead')
            else
                fibaro:debug(i..': Now OK')
local sourceTrigger = fibaro:getSourceTrigger();
if (sourceTrigger["type"] == "autostart") then
    while true do
        fibaro:debug('Scene automatically called.')
        -- Wakeup nodes only Monday-Saturday from 10:00 to 11:00
        if ((currentDate.wday >= 2 and currentDate.wday <= 7) and (currentDate.hour >= 10 and currentDate.hour <= 11 )) then
            fibaro:debug('Nodes automatically waked up.')
            wakeupDeadNodes()
        fibaro:sleep(30*60000); -- Run every 30 minutes
else
    if (startSource["type"] == "other")
    then
        wakeupDeadNodes()
Once i click on "Start" to debug the LUA code it says:
[DEBUG] 17:28:40: Wakeup dead nodes.
[DEBUG] 17:28:40: line 15: attempt to compare string with nil
Please check the code and help me, i don't know what could be wrong with the code, i think is fine.
Thanks in advance!!
5 answers to this question
I trust you resolved this issue way back. I accidentally ran into your post, searching for something else.
Quote
I assume the issue is that '>=' does not work for strings. If 'status' is a string, first make it a number using tonumber():
If it is already a number, it is even easier:
could you kindly explain to me how to correctly perform the scene?
I have the same problem
thanks
Hello ,
in the code you can find this multiple times :
And you need to change :
in
Using  tonumber(status) HC2 will allways know that status is a number and not a string (text);
Edited by madmann95
tks
i have change but this is the error give me
/monthly_2020_06/error.png.2c43992473af73429cb1364bab6f57e9.png" />
if status ~= nil then
local d_status = "dead"
else
local d_status = "ok"
