Fibaro Intercom, Helios IP Force & Fritz Box 7390
Guest spazpeker
Guys
I currently have the IP Force intercom connected via SIP to my Fritzbox when anyone pushes the button it rings the phones and we can type in the Pin to Open the Gate
It also is connected to HC2 via the Helios Gold Plugin you can see the camera and open the gate via the APP works ok
However I cant get the Fibaro intercom to work at all
The Helios IP Force does have a SIP 1 and a SIP 2
I think the problem is I cant have the same 5060 sip port on 2 devices ?
however I cant change either the HC2 or Fritzbox SIP Port or can I ?
has anyone else got a similar combination to work ?
4 answers to this question
Guest spazpeker
    Wow 27 views no replies !!!!!!
    Maybe it's possible with ssh connect to HC2, but nobody except Fibaro cannot connect into HC2 with ssh.
    @Fibaro: That could be good future request to make possible to change ports. For example from port 80 to port 53980.
    I have a Helios IP Vario; It's added as a camera and as a intercom but I can control it just on my own LAN. At 3G or 4G  it stops unfortunately
    Hi, did you find a solution for the above? Have a very similar setup with 7390 and hc2 and am considering getting a 2n Helios ip phone... Thanks! Karsten
