Adding a sjablon
Den James
When I install a Smart Switch 6 in my Fibaro, it says that there isn't a sjablon for this device. Then I get the possibility to download a sjablon. This is .xml file.
What do I do with this file?
James
​The english word you are looking for is "template" search the forum and you'll se that you are not alone =)
You don't do anything with the template other than perhapps send it to [email protected] and tell them what devise and version you have. If you do that and cross your fingers then perhapps in a year or two fibaro will add the template to a future release. Fibaro will say thank you and say something like "it will soon be added" -but you know that it wont be anytime soon- and there is no official list of devises that have templates so you will be forced to read all the release notes in all the future version and hope that someday you will find your device in the list. Or just ignore it, they probably already have that template anyways and will add it sometime soon or not so soon.
Fortunatly most devises works fine without templates since a template is well... after all just a template. Some devises unfortunatly do not work at all or with a limited functionality since fibaro havent got around to adapt their software to every single devise that used to work well in version 3.xx
