Idea how to monitor people at home
Guest Roman
    127.0.0.1 - is IP address of your Fibaro HC2. You don't need to change it because this is internal IP. It's always 127.0.0.1
    You just need to change variable with MAC address of device, which you want to find in home network.
    For example this is MAC address of your mobile phone.
    So this script will be able to scan your net and try to find your phone.
    Result will be saved to global variable. And this variable could be used in different scenes.
    • 3 weeks later...
    can't get it to work
    i have a asus RT-N66U router
    mac is 00:24:01:CB:D6:02
               48:5A:3F:6D:95:F4
    got two android phones neither works
    what am i doing rong??
    Guest Roman
    Could you try to change lower case your this address:
    00:24:01:CB:D6:02
    to
    00:24:01:cb:d6:02
    this will change status when the arp discovery is reset i think so you will get false readings of false even though you are still connected?
    Yep that's it. Thanks man.
    • 1 year later...
    On 3/17/2016 at 6:03 PM, marton said:
    Sure! It works with iPhones, we have two and no problem! So I run a script every minute to check if the phones are home or not. It updates a database and also runs a scene in HCL. In the database I store the bluetooth mac addresses of the phones and their static ip addresses. I set it up in my router so that the phones get the same ip address every time. With this I just add another line in the database and I can check 3 phones, and so on.
    I am using a file to store if someone was home, so I won't update the HCL every minute, just when a change happens.
    Here is the script, but please forgive me for any coding nonsense as I have very-very little knowledge about how to code. However this works
    /emoticons/default_smile.png" srcset="https://forum.fibaro.com/uploads/emoticons/[email protected] 2x" width="20" data-emoticon="" />
    #/bin/bash
    file="/home/pi/yes"
    anybody_home=0
    date=$(date +"%H:%M");
    #check if someone was already home
    filecheck=$([ -f $file ])$?
    while read -a row
    do
        #echo "${row[0]} ${row[1]} ${row[2]} ${row[3]} ${row[4]}"
        #check for bluetooth and ping
        btcheck=$(hcitool name "${row[3]}" | grep -q "${row[0]}")$?
        ping=$(ping -q -c1 "${row[4]}" > /dev/null 2>&1)$?
        #echo "btcheck: $btcheck  ping: $ping"
        #someone is home but was not before
        if [ $btcheck = 0 ] || [ $ping = 0 ]
          then
          echo "${row[0]} is home"
          anybody_home=1
          if [ "${row[1]}" = "no" ]
            then
             mysql --user="user" --password="pass" --database="home_automation" --execute="UPDATE anybody_home SET ishome='yes', date='$date' WHERE who='${row[0]}';";
          fi
        fi
        #someone was home, but not anymore
        if [ $btcheck = 1 ] && [ $ping = 1 ] && [ "${row[1]}" = "yes" ]
          then
          echo "${row[0]} is away but was home before"
          mysql --user="user" --password="pass" --database="home_automation" --execute="UPDATE anybody_home SET ishome='no', date='0' WHERE who='${row[0]}';";
        fi
    done < <(echo "SELECT * FROM anybody_home" | mysql --database="home_automation" --user="user" --password="pass")
    echo "Anybody home: $anybody_home"
    if [ $anybody_home = 1 ] && [ $filecheck = 1 ]
    then
     #someone is home, but not before, updating fibaro
     echo "someone is home, but not before, updating fibaro"
     curl -G "
     touch $file
    fi
    if [ $anybody_home = 0 ] && [ $filecheck = 0 ]
    then
     #someone was home, but left, updating fibaro
     echo "someone was home, but left, updating fibaro"
     curl -G "
     rm -f $file
    fi
    @marton
    do you have a video or specific instructions on how to set this up? anything would be great! thanks
    Hi @Roman
    Im new to Home center and not sure how to make this work
    i have tried making a new virtual device then added a button then added your code but nothing happens
    went into the debug then hit start and nothing ether
    what am i missing
    Thanks For any help
    • 10 months later...
    Have copyed your code, placed it into a scene and changed the mac address.
    Have also created a variable called UserAtHome
    But I an only getting the error:
    [DEBUG] 14:03:56: [1;31m2018-08-07 14:03:56.977862 [ fatal] Unknown exception: /opt/fibaro/scenes/113.lua:8: attempt to index global 'Net' (a nil value)
    Line 8 is:
