var or local var
Is there any difference in scenes or VDs between
  a= 3
  b= 2
  c= a+b
and
  local a= 3
  local b= 2
  local c= a+b
Thanks!
You need a bit more code to see a difference, you need a "block". See:
Because a scene or a VD is a unit on its own, you won't notice a difference at the main level. But technically speaking, you should use "local". When you are using variables in a function or in a if-then-else-end the difference is important. It's explained after that link.
    Thanks Petergebruers,
    I bought Ierusalimschy's book immediately, inside outside a function is now clear.
    There is a new question: what do you mean with 'But technically speaking, you should use "local".' (at the main level) ?
    Does the code run faster or does it need less ressources with 'local var' than without ?
    Thank you!
    On an HC2 it doesn't make a difference. I'm not fanatic about using "local" at the main level. It can make a difference on other platforms. If you want to experiment with Lua, you can try the excellent multi-platform "ZeroBrane Studio".
