I have an LG Smart WebOS TV and I can't add it to my HC2.
I've connected the TV to my wifi network and I can ping it. I have downloaded the plugin within my HC2. When I try to search for the TV from the HC2 I can't find it.
What am I missing?
My HC2 is version 4.080
9 answers to this question
What am I missing?
Did you try to set IP address manually?
Don't work for me also.
Strange, I have LG Smart TV and it works perfectly.
Could you check the IP address on TV and to verify access to the internet?
I believe you have installed LG TV plugin and not Wake on LAN
You can start TV with wake on lan ?
Yes, I installed remote control for LG because I want shutdown the TV.
Is any other device can discover the TV? Not just ping....
For example:
You PC should see LG-TV as a media device (open my computer and go to the network) - see attachment.
It might be that you need to open network discovery on TV.
Try to play with network setup options on TV.
My computer can see TV and I can control it from my phone but can't discover from fibaro :/
I guess you have a new/recent LG model (2015/2016)? I have the same issue. The plugin only seems to work with the older models. Apparently LG changed the api/communication and authentication in recent models. I'm afraid we need to wait for an update to the plugin to also support newer models.
Rene.
Hello, we would like to update too. I have another 2016 LG with WebOS 3 and I can't link it...
Thanks!
