daniemare 4
Hi, I have a first gen Dimmer module. It has been working great until I updated to 4.080. At first I could not understand why the dimmer lights it control will not switch on or off when I press the switch, but the associated lamps do. I had to revert to the iphone app to switch of my lights.
I then realised that it is because the dimmer's settings (parameter 14) reverted back to it's default value of "momentary switch". I use a toggle switch to control these lights (dimming is done via the app). I need to change this setting to option 1 - Toggle Switch, but every time I make the change and press save, it just reverts back to option 0 - momentary switch
What am I doing wrong? Is anyone experiencing the same or has found a solution?
