yool 0
Hi
I couldn't figure it out if it's me or the device not supporting this scenario.
The entire house is already dimmable it's all done with zeptrion 3306 from feller. I thought I could just incorporate a dimmer2 module but the momentary dimmer switch doesn't work in conjunction with the dimmer module. I tried 2 and 3 way wiring. Is that even possible or do I need to use a relay switch module?
thanks
