Can anyone tell me if new templates in an update should automatically be available to registered devices that need it, or do I have to exclude the device and include again for the template to be applied and have all parameters available.
I have a Yale Z-Wave front door lock that's included but only with basic parameter I added. The latest version of software for Fibaro HC2 (4.080) has the template for this lock but I don't see any extra parameters available. In the advanced tab it still says it 'does not have a template'.
Should it be excluded then included again?
Yep.
Normally you should not have to include exclude but in this case I think you have to include it in secure mode.
Guest chaicka
For Z-wave door locks, it needs to be included in secure mode. Hence, for this particular situation, you may want to re-include it.
Here is how a Yale Z-wave door lock will look like after correct inclusion and it does not indicate device lacks of template though there is no additional parameters to configure:
  • 1 month later...
Hi I'm think of adding a Yale lock into my system, but was wondering if the new template for this device gives you anything new?
Guest chaicka
If you are looking for stability, yes.
If you are looking for feature, no there is no new feature added and pin code changing is not available yet too
