Modubus Solar Panel to zwave
Is there any solution that will convert Modbus reporting to zwave
/emoticons/default_smile.png" alt=":)" srcset="https://forum.fibaro.com/uploads/emoticons/[email protected] 2x" width="20" height="20" /> ? I want to measure the amount of KWH that my solar panels produce, and based on that output, use Fibaro to do certain actions.
Probably it is possible to write some "addons" to work together with some Modbus interface device like this one:
Guest Kuuno
hi
we have done this modbus integration with Fibaro many times. Do you have modbus registers from supplier or can You ask for them?
I wonder if a Fibaro Wall Plug can work in reverse? If so, this would be a good solution
