hi
i trying to make a scene with WOL but with no success
I already have one scene that turn on the projector, home theater and i whant to wake up xbmc(KODI) with WOL but there are no options in the scene maker to do that
thanks
i have that setup using LUA,
have had a look in block scene and looks like it cant be done. i didnt see the options.
under lua
fibaro:call(deviceID, 'turnOn')
 %% properties
 %% globals
 -- convert MAC adress, every 2 Chars (7-bit ASCII), to one Byte Char (8-bits)
local selfId = fibaro:getSelfId();
 local icon = fibaro:get(selfId, "deviceIcon");
 fibaro:call(selfId, "setProperty", "currentIcon", icon)
function convertMacAddress(address)
   local s = string.gsub(address, ":", "");
   local x = "";  -- will contain converted MAC
   for i=1, 12, 2 do
     x = x .. string.char(tonumber(string.sub(s, i, i+1), 16));
   return x;
 fibaro:log("Start process");
 -- MAC adress
 local _macAddress = convertMacAddress("74:D0:2B:7F:B5:6F"); --put here your macadress
 -- Create Magic Packet 6 x FF
 local _magicPacket = string.char(0xff, 0xff, 0xff, 0xff, 0xff, 0xff);
 -- Broadcast Address
 local _broadcastAddress = "255.255.255.255";
 -- Default port used
 local _wakeOnLanPort = 9;
 fibaro:sleep(750);
 for i = 1, 16 do
   _magicPacket = _magicPacket .. _macAddress;
 fibaro:log("Magic packet successfully created");
 fibaro:sleep(1000);
 socket = Net.FUdpSocket();
 socket:setBroadcast(true);
 local bytes, errorCode = socket:write(_magicPacket, _broadcastAddress, _wakeOnLanPort);
 --check for error
 if errorCode == 0 then
   fibaro:log("Successfully sent");
 else
   fibaro:log("Transfer failed");
 -- clean up memory
 socket = nil;
 fibaro:sleep(1000);
 fibaro:log("Please wait for the server startup.");
