What is wrong with this scene?? One device operates, the second one doesn't
What is wrong with the code below? I have had this script and it has worked fine for over a year now. But since upgrading to 4.080, it has intermittently stopped switching on the second device (ID 43). The scene is triggered when my main light in the kitchen is switched on, it should switch on the 2 RGBW relays too. The first relay (ID 36) always abides by the statement in the LUA script but the second one is not always responding. As stated, this has worked for over a year and worked for a few weeks in 4.080 but has over the last week started behaving the way it has now.
I overcome this issue, I setup 2 block scenes, one to switch on and other to switch off when the light status changes and that works fine. However, I want to limit the number of scenes I have. I can't work out what is wrong with this.. Any ideas?
%% autostart
%% properties
14 value
%% events
%% globals
if (fibaro:countScenes()>1) then
  fibaro:debug('Kill second scene!');
  fibaro:abort();
if ( startSource["type"] == "property") then
 if ( tonumber(fibaro:getValue(14, "value")) > 0 ) then
  fibaro:call(36, "turnOn");
  fibaro:call(43, "turnOn");
 elseif ( tonumber(fibaro:getValue(14, "value")) == 0 ) then
  fibaro:call(36, "turnOff");
  fibaro:call(43, "turnOff");
try adding a small pause in between the on commands
i use this and it seems to respond better
    Ahh ok.. will try.. thanks
