I have 4 multisensors,
1 Aeotec gen5 ZW074
1 Fibaro MultiSensor ("type": "com.fibaro.FGMS001", older non Z-wave Plus)
2 Fibaro MultiSensor ("type": "com.fibaro.FGMS001v2", z-wave plus)
The two first ones on the list works fine but the two Fibaro v2 sensors will not work properly. I have done multiple excludes / includes and reconfigures but still nothing.
They kind of freeze up and stay breached for several hours and suddenly I get a false alarm when no one is in the room. I have enabled push messages to monitor them.
I do not believe the "Lux bug" is the problem here as I have default Parameter 40 (200 lux).
Had an idea it was because they are z-wave plus and I did not include them with security. But if I try enabling security at inclusion they will not get configured properly.
If it was only one sensor I would return it as faulty but I have the same problem with both newer sensors.
Any ideas?
Regards
Stian
    With the help from A.Socha we figured this was a corruption in my z-wave settings. Something bad probably happened when I added Domoticz or when I tried to add VeraEdge as secondary controller.
    To test this we did a backup and reset HC2. Reincluded the MultiSensor and it worked fine.
    Restoring any recent backup still does not work and I would give myself more hazzle restoring it too far back. So I will do a reset on HC2 and add everything again
    /emoticons/default_sad.png" alt=":(" srcset="https://forum.fibaro.com/uploads/emoticons/[email protected] 2x" width="20" height="20" /> Now I know I need a backup before doing anything stupid and what to test after adding secondary controller.
    Thanks A.Socha!
    Guest chaicka
    Tip: With Fibaro HC2/HCL, every change = backup before implement change, every significant change (e.g. firmware) = backup and reboot before implement update/upgrade.  :->
