Simple scene when I'm out of in the house in the evening
I'm getting the hang of making scenes, but I'm not sure about this simple one.
I want a scene that I can activate on my android app. When I start it, I want a light in the living room tot go on between 20:00 hours and midnight.
I made something that I tought should work, but I can't switch it on with the app. I get the scene on the app, but I can't turn it on and off.
4 answers to this question
You can either make 2 scenes, and run them (on and off). The other option is to create a variable and create two scenes to change the variable.
    I made two scenes now. One that switches the light on when the sun goes down. Here I didn't check the automatic start box.
    The second scene turns the light of at midnight. This scene always is on.
    Will this work now when I leave the house and click on the scene in the app? Or do I have to add something to be able to turn the first scene on and off when I want to use it?
    I was testing and if I press play in the dashboard, the light goes on any time of the day. So this isn't right.
    Hi
    I have a lamp with a 4 watt led bulb that turns on at sunset and off at. 23:58, it is simple. It runs without me to think about it.
    2 scenes as both active and starts with the HC2.
