How to make a virtual device to switch between home and away
How can I make a virtual device to switch between the variable Home and Away? I made the variables Home and Away.
Then I made a VD. I chose '2 buttons' and labeld them 'Home' and 'Away'. But what do I fill in at ID and the textbox under ID?
16 answers to this question
    Got the sollution. Was like Kage said, but with a few things extra I forgot. So thanks Kage for getting me started.
    PUT /api/globalVariables/globalstatehome HTTP/1.1
    Host: 127.0.0.1
    Authorization: Basic xxxxxxxxxxxxxxxxxxxxxxxx
    {"name":"globalstatehome","value":"weg"}
    IP adres VD has to be set to 127.0.0.1 and port 11111.
    Change xxxxxxxxxxxxxxxxxxxxxx by the string you make on following website
    If you loging and pasword are both admin, you put admin:admin on the website and convert.
    You will get: YWRtaW46YWRtaW4=
    Fill this in on the xxxxxxxxxxxxxxxxxxxxxxxxx
    fibaro:setGlobal(globalstatehome, " Home")
    fibaro:setGlobal(globalstatehome, "Away
    where globalstatehome is the variable within Home and Away
    I filled the above in under string in the VD. A button for Home and a button for away.
    I first made a predifined variable. I named it 'Globalstatehome' and with values 'home' and 'away'
    Then I made a scene and set that a light had to go on when the sun goes down AND when the variable is set to AWAY.
    But nothing happends. I clicked on AWAY in my VD.
    What could be the problem?
    try under LUA
    I've got a HC Lite and this doesn't support LUA.
    /emoticons/default_icon_confused.gif" alt=":-?" />
    doesn't have your VD a button for string and one for LUA
    No, only string.
    try something like this
    PUT /api/globalVariables/YOUR_VARIABLE HTTP/1.1
    Host: 127.0.0.1
    Authorization: Basic YOUR _ADMIN:PASSWORD
    {"name":"YOUR_VARIABLE","value":"THE VALUE CHANGE"}
    So I put all this by STRING?
    I changed it to my settings. Could this be right? The ***** are where my pasword comes.
    Host: 127.0.0.1
    Authorization: Basic YOUR _ADMIN:*******
    {"globalstatehome":"YOUR_VARIABLE","thuis":"THE VALUE CHANGE"}
    Host: 127.0.0.1
    Authorization: Basic admin:******
    {"name":"globalstatehome","value":"Home"}
    That is my idee (don't no if it works but gif it a try)
    Tried it, but nothing happends. Thanks for trying.
    Any other ideas?
    Any other ideas?
    Hi
    You can also use two scenes.
    Nicely done. Two minds.......
    Thanks Guys been trying to work this out for some time. Now all works.  Wish there was more info on virtual device for the HCL and what you can actually do
    Hi
    Thanks guys it works great, is clearly better than scenes.
    Btw, if you are using 127.0.0.1 and port 11111, then you can leave out the authorization part. It's only needed for regular API which is running on port 80
