Is there a way the get the value of the RAM memory so i can make a script like:
if tonumber(fibaro:getValue(RAM)) > 60 then
reboot
that way i do not haven to reboot when it is not nessosary!
Is this still an issue? Do you have the sonos plug in and hugeish play lists?
HC2 = Net.FHttp("127.0.0.1", 11111)
response ,status, errorCode = HC2:GET("/api/diagnostics")
local memoryFree = json.decode(response)['memory'].free
local memoryMin = 10
if memoryFree < memoryMin then
HC2:POST('/api/settings/reboot', 'HTTP/1.1')
    Still issue
