Unable to arm one motion sensor
I've got 2 motion sensors and 1 door sensor, please see Picture 1:
I have a very simple scene, which should arm all of these. However, first motion sensor does not get armed, two other ones do.
How to fix it? I can arm it manually or via Alarm panel, but I'd like to use a scene for that.
Problematic device is FGMS001 Motion Sensor 3.2
It is not disabled and is part part of alarm.
Probably HCL and 4.080 bug?
8 answers to this question
    So after few emails with Fibaro support they told me I'm basically "out of luck", as latest Motion Sensors with firmware 3.2 cannot be armed right now via scene. Older ones work well.
    No timeframe offered for fix, neither exchanging "faulty" sensors.
    Hello rado,
    I am having the same problem. Do you have any news on this topic?
    Roberto
    New firmware should fix it within a month, I was told.
    Thanks for your answer. So, what date was it that they told you?
    Same problem.. Hope they support over air firmware updates very soon.
    I bought some Motion Sensors FGMS-001 (so old version) with Firmware 2.7 and these work
    are there any news on this?
    Ciao McEgg
    I have FGMS-001 with firmware versions 2.7 and 3.2 and they are all armed or disarmed with LUA scene on HC2 4.080 without any problems. So I don't think it is up to sensors but there's must be something with HCL. They were even tested and breached while armed and alarm was properly triggered
    /emoticons/default_tongue.png" alt=":P" srcset="https://forum.fibaro.com/uploads/emoticons/[email protected] 2x" width="20" height="20" />
