Connecting Home Termostate -Temperature-suncollector --TOON from Eneco
In Holland and Belgium we have the oppertunity to controle our temperature + sun colectors + Z-Wave
Products. So it's possible to control your Home situation on your way.
The system is called Toon from the company Eneco , an enegry distributor.
NOw this month the API has come out so it could be connected to any system that's handling Z-Wave, and/ or by developers to provide with new oppertunities.
NOw,.. IS it possible to connect a system like TOON with a available APQI to connect to Fibaro HC2?
If yes,.... How??
See link:
9 answers to this question
Somebody did a little intergration with his NAS and domotics.
there are API for this..
I'm trying to connect to the api and I'm getting results
New Scene:
function encode(data) local b='ABCDEFGHIJKLMNOPQRSTUVWXYZabcdefghijklmnopqrstuvwxyz0123456789+/'; return ((data:gsub('.', function(x) local r,b='',x:byte() for i=8,1,-1 do r=r..(b%2^i-b%2^(i-1)>0 and '1' or '0') end return r; end)..'0000'):gsub('%d%d%d?%d?%d?%d?', function(x) if (#x < 6) then return '' end local c=0 for i=1,6 do c=c+(x:sub(i,i)=='1' and 2^(6-i) or 0) end return b:sub(c+1,c+1) end)..({ '', '==', '=' })[#data%3+1]) end
local Username =  ""
local Password = ""
local Key = ""
local Secret = ""
local ManagerBaseAddress = "
local BaseAddress = "/toon/api/v1/"
local APIBaseAddress  = ManagerBaseAddress .. BaseAddress
local AppendedKeyAndSecret = Key .. ":" .. Secret
local AutorizationHeader = "Basic " .. encode(AppendedKeyAndSecret)
local urlParameters = "grant_type=password&username=" .. Username .. "&password=" .. Password
local http = net.HTTPClient({ timeout = 3000 })
 http:request(ManagerBaseAddress .. '/token', {
 options = {
 headers =
  ['Authorization'] = AutorizationHeader,
        ['Content-Type'] = 'application/x-www-form-urlencoded',
 method = 'POST',
 data=urlParameters},
 success = function(param)
        if param.status == 200 then
    fibaro:setGlobal("access_token", "")
          local tmpdata = json.decode(param.data)
          local access = tmpdata.access_token
          fibaro:setGlobal("access_token", access)
   end,
        error = function(error)      end
    local access_token = fibaro:getGlobalValue("access_token")
etc.
    Hi Pdj79.
    Thanks for your info.
    do I have to make a script in LUA?
    and fill in this script my username and password?
    What do i have to fil in in:
    local Key = ""
    local Secret = ""
    please advice.
    regards,
    And Pdj79,....
    and what is your suggestion to fill in in the rest
    local Username =  ""
    local Password = ""
    local Key = ""
    local Secret = ""
    Any updates in this thread?
    I am still working on being able to set the temperature on Toon through a scene or device on HC2
    I got the credentials username, password, key and secret from
    I defined a global variable access_token.
    I used the script above @pdj79 for the token request
    No errors, I was able to generate/retrieve the token and save it to the global variable.
    Next I read
    See attached immages.
    I would like to read out the status and change settings like the status and the temperature.
    For instance the status.
    curl -X GET -H "Authorization: Bearer access_token"
    should return something like {"success": true, "thermostatInfo": {"currentTemp": 2000, "currentSetpoint": 2250, "currentDisplayTemp": 2250, "programState": 0, "activeState": -1, "nextProgram": -1, "nextState": -1, "nextTime": 0, "nextSetpoint": 0, "randomConfigId": 1804289383, "errorFound": 255, "boilerModuleConnected": 1, "realSetpoint": 2250, "burnerInfo": "1", "otCommError": "0", "currentModulationLevel": 100, "haveOTBoiler": 0}}
    How do I translate this and the other 2 put's into a lu script?
    Thanks for any help
    Just a remark.... Toon (=Eneco) is selling Fibaro products like the Fibaro wall plug! So a good recommendation for Fibaro.
    Hi Guys and Gifs :)
    Who is willing to share a nice Virtual Device which I can use as a starting point for my Toon integration with my Fibaro HC2 :)
    Hi @Patrick... wondering if you by now are able to control the temperature on your HC through Toon?
